S bus setup for a large jet using 12 FG TX
Hello,
I am looking into the possibility of installing an S-Bus setup in my new project, a large Feibao F-15 E 1/7 scale jet and using My Futaba 12 FG TX and 6014 RX.
I am not familiar with S-bus installation and different parts required, therefore, i will need advice on what exactly to choose (S Bus compatible servos, different connectors , cables etc....).
The following functions will be installed:
A- Elevators 2 (1 for each side)
B- Rudders 2 (1 for each side)
C- Nose Gear
D- Ailerons 2 (1 for each side) with possibility to use as flaperons (crow braking)
E- Flaps 2 (1 for each side)
F- Some of gear doors will be activated by servos and others by electric actuators. (final setup not known at this moment).
Jet will also have following features:
- Electric retracts
- Electric Speed brake
- Electric canopy actuator
- Smoke pump
- Lighting system.
On the other hand, please advise if normal servos for alternate functions can be installed on same RX in parallel to S-Bus System.
Hope you are able to assist and if you need more details please let me know.
Best regards,
C- Nose Gear
- Electric retracts
- Smoke pump
- Lighting system.
Best regards,
