14MZ - Warning when turn on TX about Throttle position.
Hi,
When You turn on the radio, 14MZ,you get a warning to Continue (turn On) if throttle position is about 1/3 up or higher.
I would like to have it set to just one click on throttle stick but it seems not possible. In Linkage menu page 2/2 you can set Warning to throttle position to On or Off but not desired position on the throttle stick.
Is the throttle position in this case fixed to about 1/3 up and can not be set to desired position for the warning to go on?
On my radio where I have full travel on the throttle stick (throttle stick travel restrictions was removed long time ago) I have 5 clicks and if I turn the radio on I get warning about Throttle positon, so at 4 clicks and lower I get no warning. That is way to much throttle in my opinion.
/Bo
/Bo
RE: 14MZ - Warning when turn on TX about Throttle position.
The purpose of the warning for the throttle position is to warn electric flyers that the throttle is not at the low position. That is to prevent accidents caused by the motor turning on unexpectedly, and to prevent having the speed control become armed by accident. The position of the stick cannot be changed, but is set by the factory.
