Wireless trainer system and T18
Hello
I open a new thread because I have a big problem to set up my T18 and my FUTM1010.
There is my set up:
Teacher TX : T18
Student TX : T14 2.4GHz set up with a new model and in 7 channel mode and in the trainer menu "student" activated. Channel set up Ok (controleld on a model)
I have set up my T18 like it: trainer mode INH=> OFF switch F channel 8ch
When I plug the FUTM1010 on the T18 after I have binded it with the T14 (controlled by switch on/ off the T14 and the led goes red fix to green fix) I can't activate the trainer system by the switch (the indication (act/inh on the T18 screen stay OFF).
If I make the same procedure with another T14 the system works perfectly (passed off/on without any problem)
So I need help because I can't use the FUTM1010 on my T18.
I'm sure that the FUTM1010 works because with 2 T14 it's working. I think there is a problem on the T18.
Does anyone has ever had the same problem?
Thanks a lot for your answers and sorry about my english.
Thanks a lot.
best regards.
Fifou
There is my set up:
Teacher TX : T18
Thanks a lot.
best regards.
Fifou
First make sure you get the WTR bound to the 14MZ. Remove the WTR from the 14MZ, plug it into the 18MZ.
Go back the 14MZ, turn the Trainer back to INH.
On the 18MZ the switch should be on or off, depending on which switch you are using. The Teacher should ON, this should be in 8CH mode. Then set the switch to whichever switch you choose. The screen on the 14MZ and the 18MZ will look identical, only that the 14MZ will say INH instead of On or Off.
Until the WTR7 is plugged into the 18MZ, moving the switch back and forth will not change On to Off. It will always show Off.
The WTR7 works fine with the 18MZ if the steps in the WTR manual are followed exactly.
Sincerely,Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,Krysta
[email protected]
The setup would be the same for the 14SG also.
Sincerely,Krysta
[email protected]
Sincerely,Krysta
[email protected]
Hello Guys.
I have solve My problem few days ago.
Krysta says exactly the good procedure.
In fact I have forget to put the 8ch mode in my T18 just under the teacher button.
Without this set up (12ch or 16ch) the WTS don't works. You need to be in 8ch mode.
So as usual Futaba have made a great system.
Thanks a lot for your answer Krysta.
Best regards.
Fifou
Best regards.
Fifou
