14SG and Flaperons
What wing type did you choose in your 14SG?
If you chose, Normal, 2-ail and Normal tail. Then I would just go into Camber mix in the Model menu, activate Camber mix, set this on a slider, then dial over to AIL. Here you can go in and set the rates for the amount of flap you want from the two ailerons when you use the slider.
Sincerely,Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,Krysta
