Futaba FASSTest R7003SB Receiver and Mini V-Bar w/ Telemetry....problem?
http://www.helifreak.com/showthread.php?p=4905043
Does anyone know at Futaba if this problem has been fixed yet? I was going to buy a Futaba R7003SB Receiver to install in
my Trex 500 FBL to use telemetry (ext V) until I read this! I find it hard to believe that Futaba doesn't have a bulletin posted on this! Is it safe to use
the receiver with a Mikado Mini-V the way it is?
Also Tower says the receiver comes with the EXT Voltage Cable......but isn't also a $50 Sensor needed for this to work? What good is the cable if the sensor isn't provided?
Michael
Michael
Futaba does not test their equipment with non-Futaba units. Their receivers work well with all other Futaba components intended to be used with their receivers. If a non-Futaba equipment maker's product is not compatible with Futaba equipment, it is up to the maker of the non-Futaba equipment to make it work with Futaba equipment.
We cannot comment on whether any piece of Futaba equipment will or will not be compatible with any piece of non-Futaba equipment.
The wire that comes with the receiver plugs into slot #2 in the R7003SB receiver as shown in the receiver's instructions, but you also need to obtain the:
FUTM5551 CA-RVIN-700 EX VLT CBL R7008SB
That connects the battery pack to the cable. The voltage sensor allows you to plug into any S-Bus port. The external voltage cable can only be plugged into one specific location.
