Ail to Rud on 14 MZ
Ail to Rud on 14 MZ
I have this set on my model to move the Rudder a small amount with the Aileron stick.
I touch the "switch" and are sent to a new page with on-single-on?
What do I do now..... to select a switch to be able to turn this function on and off....do I go ahead and push "single"?
Jim
Jim
When you select the switch-setting option in any mix, it takes you to a page that has three things to select. The first one tells you whether the mixer is turned on, off, or is inhibited. If you activated the mixer, but haven't selected a switch, it will say "ON".
The second button tells you whether the mixer is in SINGLE or LOGIC mode. "Single" means that it takes only one switch to turn it on. "Logic" means you need two switches to turn it on.
The third button is where you select the switch. If no switch is selected, it just says, "SWITCH". Select it and you will be taken to the page that selects the switch. Once you've selected the switch, the lower right-hand corner of the switch selection screen has "ON/OFF", where you can select the switch positions that turn the mixer on and off.
This is all explained in the manual on page 86 and page 126.
