T8J, R2008SB glitching on startup
GA
I have a T8J Tx and an 2008SB receiver combination installed in a plane that I have been flying for well over a year. Recently, I noticed some slight glitching on rudder servo. None of the other channels were affected. Now, after powering up the Tx and receiver, all of the servos slowly "tick" a few degrees around center, as if they are looking for the transmitter signal. After 5-15 seconds, all servos re-center and the sticks work again. None of my other planes are affected with this problem. Voltage on the flight battery was fine. The plane has a mix of Tower and Futaba servos. I tried to re-bind, but no luck. Is there a way to "wipe" the memory of the Rx and start with a fresh bind procedure? Or am I on the wrong track here? Anyone have any thoughts or ideas? I'm open to all suggestions.
Re-linking does nothing. There isn't anything in the receiver's memory except for the failsafe position, and that's updated by the transmitter every few minutes or so. How do you power-on? You should turn on the transmitter first, allow it to boot up, and then turn on the receiver. If you turn on the receiver first, some glitching would be normal until the transmitter is fully booted and on online.
