Slave chl ( gear ) used as second elev doesn't move when Crow is activated
My Feedback: (7)
I turned on Crow because I have flaps and want to use the elevator to compensate for any ballooning during full flaps, I'm also using chl 5 gear as my second elevator on a mix but when Crow is on ( full flaps ) only chl 2 elevator moves, my second servo on chl 5 doesn't.
10CAP 2.4 and 7 chl Fasst receiver.
Thank you Bill
Thank you Bill
When you have two elevator servos working, are you using the Ailevator function? Usually, channel 5 would not be used by that function, so you must be using a pmix. The airbrake mixer won't recognize that a pmix is controlling the second elevator channel. You would need to use another pmix with OFS (offset) as the master and the gear channel as the slave. Set the percentage to match the elevator channel and the switch to turn it on the same as the airbrake switch, and you'll be OK
