Need help setting up temp sensors on 18mz
My Feedback: (18)
I have telemetry on other jets, so I have a rough understanding of how to set it up. I have the futaba and robbe temp sensors. I cannot get them registered. I get a green LED on start up, but it's not recognizing them.
1. What sequence of numbers do I use in the ID box? It won't allow all eight.
2. Do I have to register after ID?
3. Is it slot specific? It says 1 is the default, I want to use two.
4. The temperature choice defaults to the robbe, will that work for the futaba sensor as well?
My Feedback: (18)
Hi Bill,
They do not auto allocate the slot. You have to assign/register them. The manual did walk me through it. It discusses telemetry in three different sections of the manual, the last one had it and I overlooked it. You have to make a Y cable and power the sensor and plug it into the back of the 18mz, then it was pretty easy.
