CA-RVIN-700 External Voltage Input Cable wiring
Bax-
I have one of these and the instructions say "Cut approximately 30mm of the positive (-, black) line from the cable."
And the sketch says "The fuse should be attached as close to the external power supply as possible. Fuse to Black line (-)"
So which line do I put the fuse in- the black or the red? Since red is positive and black is negative.
I plan to attach a pdf of the instructions to this message for your reference.
Thank you
Ed Mullen
[ATTACH]2100248[/IMG]
Thank you
Ed Mullen
