Servos losing programming or TX wacky??
My Feedback: (158)
So I have a 10 cag, and mostly use Hitec digitals, Been experiencing subtrims and end point moving off previously set positions on a couple planes at least 3 now to date, I notice this when using multiple servos per channel, like dual elevator servos, I get to the field and one is off where they were matched via the TX mixing before.
Today I was working on my P-47 which i have a 5645 programmed to 10% speed and endpoint set via the programmer, it works my tail wheel retract. Runs off TX chn 5 which is still set 100/100%,, While working on the plane I notice the endpoints are now off on that one too, so much to the point it broke the servo tray loose.
Could I have done something or should I send the TX in??
tia
tia
My Feedback: (158)
Well, in the case of the gear servo No, TX end point was and still was set at 100/100, I had that servo programmed to set the end points.
Last time I noticed it before, it was dual elevator servos, they were not programmed although they are hitec 5625s, plane had flown and was trimmed, then I took the plane out a week later and they were not together any longer.
Same thing happened on a Cub I have Using Ail-dif, they became unmatched,, Trims were off almost like the subtrim was moved
only common denominator is the TX
My Feedback: (158)
Well good news and Bad news,,
I took the Raven out and while I was re programming the ELE mixing I notice that channel 8, which I was mixing with 2 had rotary nob VR(B) assigned to it instead of how it should have been set to "Null", once I fixed that the surfaces were again matched. Obviously I had moved that nob. Looks like this situation was user error after all on that aircraft, Still can't figure out why the Cub aileron servos were off, they were just Y harnessed on cnl 1, and the p-47 flaps being off is still a mystery too since I completely changed that programming after the problem, but could have been the same issue as the Raven.
Bad news,,,
Hovering the Raven about 75' up when it starts to drift towards the pits, I try to fly out of the hover and realize I have no control,, plane goes in full throttle in the corner of the pits. Fail Safe should have killed the motor, but didn't, Luckily no one or the thing was hit. Just a destroyed DA50 and aircraft. Rx will be canned as it blew apart,
So after I thought it was me not the TX, something lets me down big time,, the TX?? still a mystery, I'll send it in for testing I guess after my new TX shows up.
Bad news,,,
My Feedback: (158)
I wanted to update this thread again,
I finally got around to fixing my 60 size Cub,, wind blew it of the start stand a couple months ago,, anyway Turned it on and the elevators (not the ailerons after all) were off again, looked and yes, just like the Raven the Ele-Flap mix Channel 6 was assigned a knob also, set switch function to null, the mismatched issue fixed. So the wacky servo issue was user error on my part, not the TX. The lock out?? might never know,, things happen,
Bax, thanks for the responses.
