Futaba 10cag flap settings
My Feedback: (18)
NC
I have a futaba 10 CAG and I am attempting to set up flaperons on my Cessna 182 to help slow her down on landings. I have flaperons on but I can't seem to set them so they only go down and not up into I guess you would call spoileron? I want the channel set on the slide switch on the left of the transmitter. (side of the transmitter case on the left) Like I say the flaps go from all the way up to all the way down and I only want them to go from center down. End point on ch 6 only sets one flaps movement and flap trim sets the amount of movement up and down together. Any help would be great.
On a switch, you can only get up, middle, and down. To get flaps stowed, 1/2-flaps, full flaps, you should use two point mixes with hardware as the master (or offset) and one aileron channel as slave on one mix and hardware as master and the other aileron channel as slave, and set the points to give you what you want.
