12 FG snap setting using sticks
HI, I would like to set up my 12FG to activate snap settings using a stick or sticks. I would like to be able to fly a positive or negative snap and to the left or right and trigger this with the sticks. Can this be done in the snap roll function or is it best to do this using the logic functions? How do I set this up, please? Many thanks for any help you can provide.
Dave
Dave
You'll need a separate condition for each direction of snap, so you'll set the snaproll function to "Single" in each condition.
You set the snaproll function so that the main and safety "switches" will be a stick positions. You can set when the function turns on where you set the swtich position. Then, set the control percentages to suit.
