Futaba T 10 J swashplate mixing problem
Hi there!
I have an issue with the setting up of my thunder tiger mini titan e325 swashplate.
As the swashplate uses 120 degree angles i set up HR3 mode in the menu,the swashplate moves in the correct direction in pitch mode as does the lateral cyclic control but the longitudinal cyclic is inverted and i cannot seem to be able to correct this problem.
Can somebody help me?
Best regards, Michael
In the 10J, you can adjust the swash AFR, page 123 of the manual. Set whatever number for elevator that will give you the proper movement. It can be a positive or negative number. Just set whatever number does the job.
You may need to set a combination of swash AFR and the servo reverse to get things moving correctly. No way to tell until you start to work with it.
