Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Two Cell LiFe Receiver Battery Pack
Old 07-13-2016, 08:23 AM
All Day Dan
All Day Dan's Avatar
Default Two Cell LiFe Receiver Battery Pack
Hi Bax, My Futaba receivers and analog servos are rated at 4.8 to 6 volts. Can I use a two cell LiFe battery pack without a regulator? Thanks, Dan.
Old 07-13-2016, 11:32 AM
Bax
If you're talking the older receivers on 72 MHz, we'd say no. You will need to regulate them. They were not designed with Lithium battery packs in mind, since they were not in use at all at the time.
Old 07-13-2016, 03:15 PM
All Day Dan
Thanks Bax. It’s the R6008HS and various Futaba analog servos. Dan.
Old 07-14-2016, 12:24 PM
Bax
For the R6008HS receiver, this is from the tech notes:
Power Requirement: 4.8 or 6.0V battery or regulated output from ESC
Old 07-15-2016, 05:54 AM
All Day Dan
Got it. Thanks again. Dan.
