Futaba 3PM-FS (Continuous Bleep from Transmitter)
Hello,
Transmitter : Futaba 3PM-FS
Receiver: Futaba R133F
Servo: HiTec HSC-5998TG
I wonder if you can help me, when I switch on the transmitter it makes a high pitch sound, TRM-ST is displayed along with 100 in the top right. The only way to stop the high pitch sound is to press/hold the DT-1 button.
If I hold the DT-1 button and adjust the TRM-ST to 0 then release, it auto increases the trim setting to 100 then starts the high pitch sounds again?
It's almost like the DT-1 button is faulty, but can't be 100% sure it's a programmable setting causing the issue??
Any advise would be welcomed
Many Thanks,
Many Thanks,
