R7008SB anolog servor compatable issue
NJ
I have a 14sg and never used the receiver that came with it. Decided to use it on a new foamy since it was available. It comes with analog 9g servos. Setting up the plane, I thought I had a bad servo..buzzed and searching for center. Had a digital available. Changed it and that's all good. Now though, another one is doing same, and they seem to take turns, or right them self's on a power cycle and act up in time. Do I need to back off and get another receiver, or change the other 3 to digital servos? Thee receiver is set in mode A.
Gregg Clement
Gregg Clement
It makes no difference whether the servo is analog or digital. That's not the problem. If the servos work OK for a while, then get noisy, or stop making noise after a while, it's not the receiver. Likely it's the servo that's the problem. Especially if they're cheap servos. Good-quality servos, analog or digital, will work with the receiver quite nicely.
NJ
Thanks Bill. I thought as much. I know the 8 channel R6008Hs with the 2 speeds on them stated digitals on ch 1 to 6 when HS is used. Making sure I wasn't missing something.
Come on spring.
Come on spring.
