Futaba T6EX Dim LCD
Futaba T6EX Dim LCD
Hi
I have a Futaba T6EX 2.4GHz transmitter that has developed a strange fault.
Even when fully charged, the LCD is VERY dim.
You can make out the voltage reading at 10.1v but something is certainly not right.
Has anyone experienced this, or have any ideas what I can look at?
Many thanks,
James
Many thanks,
James
LCD screen needs ambient light to see it. Take the TX out IN the bright Sun light , if OK there then you should be good. If dim in bright Sun light you probably have some problem with the display.
