Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Y harness
Old 03-20-2019, 09:19 AM
jofunk
Default Y harness
What are the limits for putting servos on a Y harness? In one set up it would be two s3305 servos Y harnessed to one port. In another it would be one s3305 and one s3306 Y harnessed to one port. It is all Futaba equipment.
Joe
Old 03-20-2019, 10:37 AM
dbsonic
dbsonic's Avatar
Which Y harness?... they are not all made equal and some of different wire gauge.
I generally try to go for the largest gauge and quality.
Old 03-20-2019, 02:30 PM
FUTABA-RC
FUTABA-RC's Avatar
Joe
Use a good quality "Y" and you'll be fine.
Old 03-20-2019, 02:31 PM
FUTABA-RC
FUTABA-RC's Avatar
Thanks. A quick reminder, this is not an open discussion forum, it is a vendor forum for direct support. Thanks
Old 03-20-2019, 05:08 PM
jofunk
I am not a radio expert but am trying to understand. I have a few R6014FS receivers. On some of the ports the signal voltage is 2.7v as opposed to 3v on the other ports. Is there any concern about using a Y harness in a port with a 2.7v signal? Again all the equipment is Futaba. I know there are issues with some after market equipment in the lower voltage ports.
Thanks Again,
Joe
Old 03-20-2019, 10:20 PM
FUTABA-RC
FUTABA-RC's Avatar
Thanks Again,
Joe
Probably not, unless you are using very long extensions with them. Then maybe, but you would know right away.
