9ZAP module
9ZAP module
Hi,
I went to change the module on my 9Zap WCII and noticed that one of the clips holding it in was broken, so I can't take it out. Is there any way I can still remove it without damaging anything?
Thanks!
Robert.
Thanks!
Robert.
RE: 9ZAP module
Hi Robert,
You may want to try a small plastic screw driver or anything of that nature that will allow you to push up on the very end that was broken on the case. If you can continue to work the case up on each end a bit at a time, you should be able to get this out.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
