9C mixing question ccpm
I would like to know if it is possible to make channel 5 act exactly like channel 6.
radio is set up for sr-3.
if i do pitch master to gyro slave, the servo moves with stick, not with mixed pitch out put.
is it possible?
is it possible?
RE: 9C mixing question ccpm
Hi parabellum,
I would try going into your Aux Channel and making sure that channel 5 is Null. Then go back into the mix that you created and readjust the rates.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
