Futaba 9ZWC2 programming issue...
RE: Futaba 9ZWC2 programming issue...
Hi Yann,
The "sensitiviy" would be changed depending on the amount of input at each point in your curve set up.
See page 104 of your manual.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
Krysta,
Let's take an exemple.
Say you use F->E to compensate for trim changes when flaps are deployed.
You also choose RD dial as Trim Volume Setting to fine tune in flight the amount a compensation you need.
The question is, how do you set the percentage of compensation for one step of the dial.
By default, the range of adjustment is less than 10%. How do you change this ?
Yann
Yann
