7CAP turn on question
WI
I have a 7CAP with the 3151 digital servos (my first exp. with digitals). I turn on the reciever and then the radio and then I get what to me sounds like a servo hunting for position.
If I move any stick it quits and doesn't do it any more untill the next time I turn things on again. Is this normal or should I be looking for some sort of a Problem? It passes the ground test with the engine running but I have not tryed to fly it yet because of this problem.
RE: 7CAP turn on question
Hi ysrcflyer,
If you have a full load on your battery, you may notice this with Digital servos. It is completely normal and once a load is on them or the voltage drops a little this should stop.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
