7CAF or 6EXA : How to Configure Dual Throttle Servos on Seperate Channels?
WA
I have Futaba 7CAF and 6 EXAS radios. I am trying to configure Dual Throttle Servos on seperate channels. I assume if it is possible, I need some sort of P-MIX setup. I have tried to slave channels 5, 6 or 7 to the throttle channel 3 master but the slave does not respond at all. Can P-Mix not be used for throttles on seperate channels?
RE: 7CAF or 6EXA : How to Configure Dual Throttle Servos on Seperate Channels?
Hi orleck,
Yes you can use a Pmix for this. While the example link listed below is for the 9C radio, it will give you guidelines on how to set this up.
http://www.futaba-rc.com/faq/faq-9c-q511.html
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: orleck
