T14MZ vs Butterfly
T14MZ vs Butterfly
Hi all,
I use my T14 in French F3F league , due to the strong conditions, butterfly are mandatories to stop the planes.
Sometimes on different models butterfly are difficult to adjust and to modify 1 parameter i've to land with risk.
I didn't find a solutions to modify or match the parameters ( elevator/FLAP/aileron) during the flight.
I would appreciate to use rotary button or trim ( one for each, like fine tuning for other functions ) during the flight to modify the ratio and then add this ratio to the usual parameters for a final result.
Thanks for your help
RE: T14MZ vs Butterfly
Hi all,
i found a solution, if somebody is interest.
Step 1 : Program your butterfly as mentionned by the manufacturer. from my side Aileron 70% Flap 100% elevator compensation 2mm, butterfly on stick J2, half course. Next go to sevo monitor and note the value for aileron , aileron 2 etc....at full J2
Step 2 : Program 5 mixers like that .J2 to Aileron 70%,fine tune LD 20%, your preffered switch for on/off, idem for Aileron 2.J2 to Flap 100%, fine tune RD 20%, swicth as before , idem for Flap 2. J2 to elevator 20%, fine tune CD 20% switch as before.
Step 3 : You can fly and adjust your butterfly in a range of 20% ( At this time i cannot help you )
Step 4 : after landing, go to servo monitor, note the new values, next go to butterfly mixer and add the value to match the same value in servo monitor
Step 5 : Cancel your 5 mixers
Step 6 : Your plane is ready to stop with a perfect butterfly
regards
regards
