10 channels out of a 129DP or 149DP
I have heard that is possible to get 10 channels out of this receivers, I have a Futaba FC28 10 channel transmitter and want to know what is required to modify the receivers, I know that channels 9 and 10 are just two position.
Thank you.
Alfredo
Thank you.
Alfredo
RE: 10 channels out of a 129DP or 149DP
Hi Alfredo,
It is possible to send the R149DP into your nearest service center for an update which will give you the 10th channel. The R129DP is not capable of this update. Information on doing this update is proprietary information.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: A Betancourt
Thank you.
Alfredo
Thank you.
Alfredo
Krysta:
Thank you very much, I will send my 149 receiver. I have heard that the 9Z also transmits 10 channels and that channel 10 is in switch D, Could you please confirm this?
Regards
Alfredo
Regards
Alfredo
Hi Alfredo,
Yes it is in switch D, you are correct.
Thanks, Krysta
Thanks, Krysta
Krysta:
Regards
Alfredo
Krysta:
Regards
Alfredo
Krysta:
Thank you, I have another question, Why did the 9Z radio was not advertised as a 10 channel radio? I am sure that you would have atractted a bigger market that went to JR just to have 1 more channel.
Regards
Alfredo
Regards
Alfredo
