9C Super two channel Aileron Servo setup/mixing ...
How do you allocate the channels and mix these together for indipendantly adjustable aileron servos....I've done it once but cant seem to get it right now...[>:]....
Allso what channels are best for ...Flaps,retracts + a seperate servo for nosewheel steering (that has to be inhibited when the gear is up) and that has to work in conjunction with TWO rudder servos that are allready 'Y' leaded ( twin boom airframe)
I seem to have got in a tangle with the channels/ mixes...[:@]
Thanks....
Dave.
RE: 9C Super two channel Aileron Servo setup/mixing ...
The instructions have a "preferred" setup. Usually, the second aileron is set up on channel 6 or 7 if you have a 7 or more channel receiver, or on 5 or 6, if you have a lesser receiver. It depends upon the mixes being used, and whether the model is powered or a sailplane.
Thx... Powered...& 9Ch RX... its the working together of the two servos that i semm to ave got round my neck...I.E even when i plug the second servo into ch 6 or 7 ( Ail servo # 1 is on Ch 1 ) it doesent move when i wiggle the Aileron stick...[:-]
Dave
On my 9C I have Parameter = Type = Acrobatic, AIL-2 = Ch5&6
Flapperon =active
Flap Trim = active
Rx Ails in Ch1 and Ch6.
The Ailerons are fully adjustable. I hope you get it going.
Jeff
Flapperon =active
Flap Trim = active
Jeff
Jeff, Bill...
Finally got it sussed......Ch 1 & 7 and mix de-inhibited...BUT then had to allocate the gear to Ch 8 Switch 'A'.....Flaps still o.k on the L Hand Proportional slider.....
Thx....Dave.
Thx....Dave.
