servo installation
servo installation
is it possible to install servos backwards?
elevator arm & throttle arm on Tower Trainer 40 kit too long!! looks like I need to cut off about an inch!
Ed
Ed
RE: servo installation
You cannot install a servo "backwards". The output wheel always turns in the same direction with a given control input. You position the servo so that it fits best in the model...so if the output wheel (arm) is positioned where it has to be, the case can be at any position that works.
