Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Futaba R319DPS 9-Channel PCM Receiver Synthesized
Old 06-14-2007, 08:41 AM
Hammbone
My Feedback: (309)
Default Futaba R319DPS 9-Channel PCM Receiver Synthesized
Can I use the DSC port on the Futaba R319DPS 9-Channel PCM Synthesized Receiver to plug in my RX battery? I assume this must be the only way to actually use 9 channels.
Thanks, Jim
Old 06-14-2007, 01:25 PM
martinoto
Default RE: Futaba R319DPS 9-Channel PCM Receiver Synthesized
Jim, I think you will need an "Y" cable to connect the battery and the 9th servo at the BAT connector on the RX. This is the same set-up you would need in a 138 or 148 Rx to connect the 8th channel as well.
Hope this helps.
Regards
Old 06-20-2007, 04:05 PM
Bax
You most certainly can use the DSC port for the receiver battery plug. That connector, and all the servo connectors, have their "+" and "-" in common. You can also use a "Y" connector to add the battery pack to any one of the servo channels. The one marked "9/B" is one that's "suggested" by Futaba, but you can use any of the servo connectors.
Old 11-27-2007, 09:39 AM
dwilco1001
I have just purchased a second-hand Futaba R319DPS receiver. Could someone kindly explain to me what the "DSC Port" is used for, as I don't have the instructions for this item and I have never had such a socket before.
Thank you for any help.
Old 07-28-2015, 01:47 PM
thompsonlodge
Can a R319 DPS rec. be used with an 8SSAPCM?
