14mz Flaps. Help needed.
I am trying to set up, two flaps.
I have selected two Ail and Two Flap in model type, I then go to the flap menu, and try to set up the flap movement, but I am having no success.
Can You Please tell me how to setup two flaps, otherwise i WILL have to operate them on a sinle channel.
Many Thanks
Many Thanks
RE: 14mz Flaps. Help needed.
Go to Function
set Flap and Flap 2,
next go to VC and set camber with dedicated stick
After it depends on what you want to do with your flap, all mix have been generated with the model.
regards
regards
If you go into the Linkage Menu, then the Function Menu, you can see which control is dedicated to Flap. Flap2 should have control and trim set to NULL, it will work when Flap is activated. That's the control that activates the Flaps. On my transmitter, LS is the control that was automatically set up. As it's moved, both flap channels will move.
In the Model Menu, you can adjust how the flaps work in the Flap Setting option. The regular flaps are also called the "Camber Flaps" because they actually change the camber of the wing.
If you need to have one lever have flaps and ailerons deflect, with elevators trimming to compensate, you can set this in the Camber mix. My Tx had it set up on slider RST. You can also mix ailerons to CamberFLP (ail -> flap mix), or CamberFLP to ELE (elevator mixing with flaps for trimming), and so on. The names of the mixes tell you what they do.
