Futaba 9C super issue--Need help Bax
OH
Bill--I have strange & unwanted behavior with my 9C. When I am holding full up elevator (2 servos ch2 & ch8 ailvator) and move the rudder thru it's movement right to left and left to right when the rudder gets almost to it's full deflection in either direction the elevators suddenly reduce their deflection while I'm still holding full up. This only happens on high rate. I went thru all the menus and can't find any mixes set up I don't know about. It's almost like there is a rudder to elevator mix on with OFFSET set at about 90% of the rudder travel. I have a contest coming up soon and I need to get this resolved. Please help.--Thanks
RE: Futaba 9C super issue--Need help Bax
If you get the same thing happening when you create an absolutely new model, or have an old model and reset it, then we'd believe that there's something wrong electrically inside the unit. It should be sent to us.
If you do a reset of a model and the problem goes away, then you'd have to go through every menu option and setting to see why your transmitter's acting as it does.
OH
Bax--Thanks for your quick reply. I found the problem. The problem is the operator (me). All is well and I'm almost ready for the contest except for one problem. Same problem (me). It will get better when I get better. Thanks again.
