Option of Line-Spline and VTR Curve Mix
Can you please explain the use and setting method of these 3 Curve Mix options---How are they different to each other.In Aerobatic flying can you explain the use with example.
RE: Option of Line-Spline and VTR Curve Mix
Hi ajay1,
VTR is used mostly in aerobatics when you want a large amount of change quickly on your control surfaces. Line is just that, it will draw a straight line between your curve points, giving you a flatter response between these points. Spline smoothes out these points, giving you a totally smooth curve with no breaks in servo response.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: ajay1
P. Pos determines the position where the rates change, and the P. Rate is the limit of control movement. The best way to see how this works is to play with it in your transmitter. You can always reset it, or just create a new model so that you can play with the different settings without affecting any model you're actually flying.
I bought the 14 MZ in March 2005 ---I'm buying one today----Is there any upgradation especially in the working of the Touch Screen.I broke mine twice because the switches would not activate by a light touch.
Is the Software, etc, upgraded.
Difficulties with the touch screen being hard to operate were not due to software, but in the screen, itself. The screen should not need a hard push to work, just a gentle touch. Sometimes, you need to hold a second or so, but you do not need to press hard. If you do, the screen is bad.
