Brushless Servo Question
I'm aware that the Futaba S9351 servo will oscillate in some aircraft applications and that the S9155 is the aircraft version (which functions flawlessly). It appears that the BLS451 carries the same application info as the S9351 (on the Tower site) - so my question, is the BLS451 suitable for aircraft applications?
RE: Brushless Servo Question
The BLS451 servos are designed primarily for R/C car use. We don't have feedback on their behavior in other types of applications.
Can you tell me the warranty return rate has been low so far? How are they doing truck and buggies.... arguably the toughest test on the planet? What are the field reps finding? I know these might be tough questions for a distributer to answer on a public forum. I'd like you to tell me that have been bulletproof in the field so far. If that is not the case, you could recommend I put them in my other toys for a while... Will I know if there is a problem before reading about them on RunRyder or RC Universe. Or worse yet, something gets broken?
Sorry for putting you on the spot but I'm close to flying this and am searching for some/any feedback.
Bill Vail
Thanks Bill,
I completely understand how tough this question is and I'm sorry to have put you on the spot. I had hoped there was some early returns from the field. I will wait to see what time proves out.
My set of BLS451's shipped from Tower Hobbies 25 July and I got them 28 July. I still haven't found time to finish the heli so I can't add to the feed back pot yet. I'm sure I'll be happy.
Bill
Bill
Being as I ask the original question, it's seems fair that I update the info. The BLS451 appears to work just fine on the rudder of a 2m pattern model (pull-pull cables).
