12FG Question
12FG Question
Is there any more information available on what the 5th and 6th digital trims do? Are they assignable to any function you want? I've downloaded the manual and could not find much info on these.
Jeff.
Jeff.
RE: 12FG Question
The 5th and 6th trims are for whatever you want them to do. You can use them as the master control for a channel, and adjust the size of the steps, or you can set them as a trim for any other function...such as flaps. Perhaps you have spoilers...you can fine-tune the throw of the servo to adjust the max deflection in the air. Or something else...it's up to you and your imagination.
Just as you can put any function in the transmitter on a switch, you can do the same with the trims.
RE: 12FG Question
Thanks Bill. I think my 2 Stylus radios will be going on the auction block (eBay). One more question - Can you select the shift (pos or neg) in PPM mode?
Jeff.
Jeff.
RE: 12FG Question
Hi Jeff,
Yes, the 12FG does have the software to allow for shift select. In the programming STD would be Futaba or Hitec, INV would be JR or Aitronics.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: Sonic1
Jeff.
Jeff.
