14MZ and dual rudders???
My Feedback: (111)
SC
RE: 14MZ and dual rudders???
steve.. i have a 14.. and run 2 and 3 rudder servos..
i just plug in the extra rudder servos into a un-used channel.. then set the controll as the same as the rudder..under function.... works for me..
jj
jj
Select two channels. Program one to be "Rudder", and the other to be "Rudder2". Make sure "Rudder2" has the same control and trim as "Rudder". For best response, use two adjacent channels in the same group. I used channels 10 and 11 on my TX, and changed the original rudder channel to an unused Aux channel.
My Feedback: (54)
Thanks Bax,
But that didn't work for mine. I tried using the dual elevator tail and just punching in Rudder 2 for the second rudder. What did finally work was to use Rudder,,Rudder. Then it would run on the dual rates and expos that I programmed. Rudder 2 would not run on the expos unles I used the delta wing dual rudder selection.
