New 10C Radio?
RE: New 10C Radio?
Bill or Krysta,
looks like we are bombarding you, but my only concern is the stick quality.......are the stick gimbals and pots higher quality than the ones used on the 6EX and 7C?
thx
-mike
thx
-mike
RE: New 10C Radio?
Futaba 10 CHP
It’s the perfect system for the price-conscious pilot needing pro-level features; one that offers far more than modelers would expect, for less than they’d ever imagine. The 10C includes features formerly found only on Futaba’s most advanced systems like intuitive Dial’n Key™ programming and joystick navigation; Basic and Advanced menus allowing you quick access to the most used menus; programmable mixes and more. But it also offers features that our competition does not in this price range: Features like logic switches; 7-point throttle curve and two gyro settings for airplanes; 7-point throttle and pitch curves and four flight modes for helis Expanded sailplane features that include butterfly-to-elevator mix, as well as spoiler and motor cut menus are also featured. Another plus is a feature that automatically conserves power by turning off the backlight during periods of inactivity. The FASST version is complete with the R6014FS 14 channel receiver – the same receiver found in our top of the line systems (12FG, 12Z and 14MZ).
10C Overview:
Big, 160 x 72 LCD with backlighting, adjustable contrast & auto-off
Dial’n Key™ programming with joystick navigation
15-model memory (expandable with optional CamPACs)
Ten character user name
Ten character model name
Enhanced airplane, heli and glider software
“Logic Switches” activate a new condition if specified switch positions occur
Up/down, on/off timer (activated by stick or switch)
Tracks service hours for radio and models
Mode 1-4 selectable (Modes 3 and 4 programmable)
Assignable functions/switches
Auxiliary channel screen for 1-step function/switch assignment and eliminating unused auxiliary functions
2 proportional slider switches
Digital trims on all 4 main channels
Trim memory and sub-trims
Adjustable trim steps (1-40)
Fail-safe, servo reversing and EPA
“Full Functionality” trainer system (cord required)
Flap switch (3-position)
Retract switch
Variable-rate knobs (3)
Adjustable Throttle Cut/Idle Down
Sticks with length and tension adjustments
1024 resolution
Servo cycle with bar graph displays
Constant trim, voltage, name and timer display
10C specifics:
Advanced Airplane Menu with eight programmable mixes (four linear/four with 5-point curves)
Nine factory-defined mixes: Elevator-Flap;, Ailevator; Throttle-Needle; Aileron Differential; Flaperon; V-Tail; Elevon; Snap Roll; and Air Brake with elevator delay
Two independent gyro settings
Seven-point throttle curve
Flap trim
Two-rate gyro system
Dual/triple rates (3 channels) Aileron, Elevator, Throttle, Rudder
Exponential (3 channels) Aileron, Elevator, Throttle, Rudder
Idle down
Advanced Heli Menu:
Accepts separate gyro sensitivity, governor speed and servo travel rates for up to 4 conditions and automatically changes all three with a change in condition.
Six programmable mixes (four linear/ two 5-point curves)
Eight factory-defined mixes: Hover-Throttle; Hover-Pitch; Throttle-Needle; Governor: Offset: Revo (5 point); Delay; and Throttle (aileron/elevator/rudder)
Gyro menu
Eight swash plate types
Swash plate AFR
Four 7-point throttle and pitch curves with delay (N, 1, 2 and 3: +/-100%)
High/Low pitch setting
Three adjustable idle-up conditions and normal condition
Throttle Hold and Idle-up with delay
Advanced Sailplane Menu:
Eight programmable mixes (four linear/ four 5-point curves)
Twelve factory-defined mixes: Butterfly-Elevator (2); Elevator-Flap (0-100%); Camber (with aileron/elevator/rudder adjustment); Aileron-Flap (0-120%); Aileron-Rudder/ Flaperon; V-tail: Flap Trim; Butterfly with spoiler adjustment and 4-point Offset (with camber adjustment for basic/launch/thermal/speed)
Adjustable spoiler
Adjustable throttle cut
Single/Dual Flap servos
Start, speed, distance and landing conditions
Adjustable motor cut
10C Overview:
Retract switch
1024 resolution
10C specifics:
Flap trim
Idle down
Advanced Heli Menu:
Gyro menu
Swash plate AFR
Adjustable spoiler
RE: New 10C Radio?
Futaba 10CAG 2.4GHz Integrated R6014HS and Airtronics SD-10G 10-Channel 2.4GHz Tx System.. these are some of the best options available for 10 channel radios.. ia m confused with which to get..[/b][/b]
