Set up Ailer. Fut T6EX 2.4???
My Feedback: (12)
MT
I use a single servo for each Ail. But I can't get it too work unless I use a "Y" harness on channel #1. Is there a way too to use channel 6 for L. Ail. and channel 1 for R. Ail. Channel 5 can be used as well...
Thanks Shane
Thanks Shane
1 Post
RE: Set up Ailer. Fut T6EX 2.4???
Y ou can in fact trim both servos on each aileron if using the Flaperon function.
Push Mode and Select simultaneously to enter the programming modes.
First up is Reversing of channels. MAke sure both ailerons are working correctly in either normal or reverse mode as requireed according to your mounting.
Now Go to channel 1 and trim it using the digital trim function. Repeat for channel 6.
Exit Rev mode and the ailerons will not trim as ailerons should trim for port to starboard balance.
Sorted.
Sorted.
