DG1 and 2
DG1 and 2
Hi
I am new to 14MZ and need to use all 14 channels, I have read the manual and see that 13 14 chanels are digital switcheable, but can the travel be adjusted I want to use one for a canopy servo and the other for a tank drop. or are they just a staight on off switch?
thanks Ian
ps I did a search and could not locate the answer and went on the FAQ, again with out luck
thanks Ian
RE: DG1 and 2
DG1 and DG2 are not really "on/off" channels, but "one end or the other" as far as servos are concerned. You cannot adjust the travel, just which transmitter control will activate them. Travel adjustment would be done by adjusting which hole in the servo arm you use. Closer to the center will give you less travel.
