7UAFS Channel Mixing
I am trying to mix channel 5 (toggle) to channel 3 (throttle) so I can make best use of an onboard remote glow driver. Ideally, I would like to use the toggle to be a master on-off for the glow, but have it work normally thru channel 3 as fully on when throttle below 30%, and off above that. The toggle will be a fail-safe master off for the glow driver - and without the toggle on, the glow driver will be inop.
The manual is very sketchy on how to do this. Can you help?
Tom
Tom
