9C conversion to 10CG questions
VA
Bax or Krysta:
1) On a Futaba 10CG Air Integrated FASST PPM/FM PCM transmitter system that is the "air" mode 2 smooth stick version, but on start-up it defaults to the "heli" mode. I only fly aircraft, what is involved to have it default to "aircraft" version on start-up?
2) I'm using my old trusty 9C with a TM-7 module and use the Futaba 617RS receivers on all my aircraft, do I just re-link all my receivers via the Easy-Link button to the 10CG?
3) Will my 9C Futaba TP-FSM synthesized module work in the 10C?
4) And finally, can I use my CAMPac 64K module from my 9C and copy all my models specifics intact to the 10C?
Many thanks.
Gary Graham
Many thanks.
Gary Graham
RE: 9C conversion to 10CG questions
Hi Graham,
1.) To change the default to "aircraft" you would need to send this ino the service center to have the software changed.
2.) Once you have you linked your receivers to the TM-7 module, you can use the module in any Futaba FASST compatible transmitter. But if you are using a different module in your 10C than the current TM-7 that you own, you will have to relink the new module to your current receiver.
3.) Yes, this will work.
4.) Yes, see our FAQ:
http://www.2.4gigahertz.com/faq/faq-...ghz-q1097.html
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
ORIGINAL: ggraham500
Bax or Krysta:
1) On a Futaba 10CG Air Integrated FASST PPM/FM PCM transmitter system that is the ''air'' mode 2 smooth stick version, but on start-up it defaults to the ''heli'' mode. I only fly aircraft, what is involved to have it default to ''aircraft'' version on start-up?
Many thanks.
Gary Graham
Bax or Krysta:
Many thanks.
Gary Graham
