Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
12FG 2.4 Question
Old 07-24-2009, 11:21 AM
SoCalSal
My Feedback: (16)
Default 12FG 2.4 Question
Hi, what receivers (2.4) will work with the 12FG (2.4)?? I know the 8 channel will work as of course will the 6014. But are there any others that will also work???.
Thanks for your help.
Old 07-24-2009, 01:21 PM
Bax
Default RE: 12FG 2.4 Question
All of these will work with your 12FG transmitter with the TM-14 FASST module installed. The 4-, 6-, and 7-channel receivers will require you to set the transmitter to 7-channel mode, while the 8-channel and 14-channel units will require you to set the transmitter into Multi mode. Some receivers listed have been discontinued.
R6004FF 2.4G FASST AIR RX 4CH
R606FS 2.4GHZ FASST RX 6EX
R607FS 2.4GHZ FASST RX 7CH
R608FS 2.4GHZ FASST RX 8CH
R616FFM 2.4GHZ FASST PF RX 6CH
R617FS 2.4GHZ FASST RX 7CH
R6008HS 2.4GHZ FASST RX 8CH
R6106HF 2.4G FASST PF RX 6CH
R6106HFC 2.4G FASST MID RX 6CH
R6014FS 2.4GHZ FASST RX 14CH
R6014HS 2.4GHZ FASST RX 14CH
