7C to 10C, question about prog.
hi there, have a question...i will change my7C radio for the new 10C, i have al my setups on my 7C of course....do i need just copy everything on the 10C? and it will work the same on my heli and airplanes?. Imean, turn on the 7C and 10C and start to check all the menu, and put the same info on the 10C. Then link the rx to my new 10C tx.
Regards,
RE: 7C to 10C, question about prog.
You would use the same parameters to start with. They'll be close. However, you'll still wind up making adjustments. That's because no two transmitters are exactly alike. There are enough differences due to manufacturing tolerances that some tweaking is usually necessary. That's true even if you can transfer a program from one transmitter to another via a memory card. Some things will likely need to be adjusted by a few percentage points.
ORIGINAL: Bax
