12fg stick problem
12fg stick problem
Hi I have had a 12fg Tx for 18 months now & seem to be having a problem with the stick units if I enable a new model even b4 I set anything at all an off set value is shown on the 3 main sticks in servo monitor this value is not always the same which means that even if I pay for a recalbration costing £60 I could have the same problem soon after . The sticks themselves seem smooth enough & even whilst watching the display in servo monitor no erratic behaviour can be seen. On surfing the web it seems that I am not alone in experiencing this problem. I have had a FF 9 Tx for many years & it has been well used with no problems at all, is there a known problem wih the 12fg or stick units causing this problem.
RE: 12fg stick problem
There can be slight differences in the sticks from absolute "zero" calibration. A point or so off is normal. When you change models and see a slight variance in the points, it's because the processor is converting an analog voltage to a digital signal. Sometimes, the result can be slightly different.
If they are wildly off, then there would be a problem with the chips in the transmitter, and it should see the service center.
