12FG Exponential Setting Question
I'm still trying to figure out how to set up the programming on my 12FGA transmitter. I have a very basic question. I want to use exponential to desensitize elevator, aileron, and rudder functions around neutral. So do I want to set the curve rates at plus or minus? I'm thinking it should be set at +70%. Is this correct? If not, what would be a good differential setting?
Thank you
JC
Thank you
JC
RE: 12FG Exponential Setting Question
ORIGINAL: Bax
Use negative exponential. Positive will make the controls more sensitive near center.
Bax,
Thank you. Please advise as to what would be a good negative exponential setting to start with. Would -20% be OK for a low-wing aerobatic model?
Regards
JC
