7c Dual elavator trim
NJ
Hello,looking to go from 6ex w/reversing Y on elavotor to 7C,will I be using a Y for batt and additional elevator servo on ch7,also there seemed to me some confusion on trimming dual elavator set up on 7C,right now on 6ex I have 1 and 6 for ailerons,hope you can understand question,any help great,thanks P.S I am using ch 5 flap for remote kill also,thanks
RE: 7c Dual elavator trim
If you are using a standard Y harness, you will not be able to trim your second Elevator or Aileron with both the 6EX and the 7C. To be able to set end points and trim the second servo, you will need to purchase a Synchronizer FUTM4155.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
ORIGINAL: skip1320
NJ
Thanks Krysta,i am trying to eliminate any Y harness,but want to trim both elavator half,s,this will be w/7c getting tommorow,saw a referance to ailevators?Does this sound correct,any info great,thanks
The 72Mhz 7C does not have an Ailevator function, if you are going with the 7C FASST version, it does have the Ailevator function in its software.
Sincerely,
Krysta
[email protected]
Sincerely,
Krysta
[email protected]
