Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Great Planes/Futaba
R6008HS
Old 04-17-2010, 09:21 PM
OldCoot
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default R6008HS
Can the R6008HS be used in High Speed mode with the GY401 gyro ?
OldCoot is offline
Old 04-19-2010, 01:59 PM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
No. The gyro requires the regular control signal.
Bax is offline
Old 04-19-2010, 05:12 PM
OldCoot
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
Would it be acceptable to put the RX in high speed and use channels 7 & 8 for rudder and gyro gain.
OldCoot is offline
Old 04-22-2010, 11:57 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
You cannot operate the GY401 gyro when the receiver is in high-speed mode. That's because the gyro goes on the rudder channel, and requires a standard signal. To have a gyro work with high-speed mode, you'll need to use the new GY520 heli gyro, which will work when the receiver is in high-speed mode. Of course, digital servos are needed.
Bax is offline
Old 04-22-2010, 05:59 PM
OldCoot
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
Not to be a pest but how about this.
I have the 8FG TX in which I could assign channels 4 & 5 to channels 7 & 8.
The way I read the manual is that the R6008HS operates in HS mode on channels 1 thru 6 and remains in standard mode on channels 7 & 8.
It says that analog servos can be used on channels 7 & 8 when the RX is in high speed mode.
Or, am I wrong ?
Thanks again,
Dan
OldCoot is offline
Old 04-23-2010, 02:26 PM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
If you assign the rudder function to channel 7 or 8, you would then set the gyro gain to the other channel (of 7 or 8). Analog servos will work fine on channels 7 and 8 regardless of whether channels 1-6 are in high-speed mode or normal mode.
Bax is offline
Old 04-23-2010, 06:14 PM
OldCoot
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
I appreciate the response !
Dan
OldCoot is offline
Old 04-24-2010, 10:28 AM
windsheer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: R6008HS
I have mine in HS mode with the GY 401. It works just fine. Standard setup rudd on channel 4 and gain on channel 5.
windsheer is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
