12 Fga as Teacher
NJ
12 Fga as Teacher
I have a 12 fga radio and the newest update. I am using a 9c as a student Radio.This is for a jet with an ECU not a servo for the throttle
I went into the 12 fga teacher programs and changed all the students channels to the normal channels.
1 Ailerons..2 elevators...3 throttle...4 rudder etc.etc.etc.
I gave acces to those channels only no gear,flaps,retracts or anyhting else.
I had to reverse the throttle on the 9c(student Radio).
Here is my problem with both transmitters at low throttle exactly the same I hold the switch on the teacher(12FGA) to let the student, fly the throttle raises to about 1/4 throttle. When I flip the switch back the throttle drops to normal. I tried to adjust the endpoint in the 9c but I can't get the throttle any lower then 1/4.
Now remember there is no trims on the throttle with a jet ecu.......
any suggestions??
everythihng else works perfect!!!!!!!
I hope I did not confuse you.
any suggestions??
