12FG Switch Logic Question
I was under the impression that the 12FG only used logic when associated with 'flight conditions' and noticed that the latest firmware upgrade added switch logic to DG1&2. Does that mean that the 12FG also has all switch logic capability the same as the 12Z and the 14MZ? Thanks
Howard
Howard
RE: 12FG Switch Logic Question
A "Logic" switch means that a function will be activated when you have the logical operation of two switches: You can use logical "AND", "OR", or "Exclusive OR". They are determined by the position of two switches. This is available for condition selection, so a condition that has its mode set to "LOGIC" will require one or two switches to be set for it to be turned on (depending upon the type of logical operation).
With DG1 and DG2, you can have them control a function based upon the logical operators. You will have to select the switch combination that makes the determination.
