Changing the switch direction on a FG12?
Hi, I'm trying to find how to change the switch direction on my FG12 can anyone give me any idea? The function i want to change is on my flaps, the flaps go down when the switch is in the up (top position), i would really like them to go down when the switch is in the down position. I know there is a way of doing it but i can't seem to find it in the manual and i can't change the direction of the servos as they are fixed in.
Yak54. |
RE: Changing the switch direction on a FG12?
When you assign the switch, change the logic around as when it is active. When you select the swicth operate it, and you will see it change.
So if it is Off-ON, change the logic to ON-OFF (or it might be active, I dont havemy tranny in front of me). Once yo see this, you will find it easy for the future. |
Thanks for that, all sorted now.
