T16SZ S3072HV The connected servo is not ready
Hallo,
I am following page 61 wiring a Y-cable to attach The S3072HV together with a receiver power source to The T16SZ . System menu/S.Bus servo When I press "READ" I get this error: "The connected servo is not ready" Servo is S3072HV I hope these servo's can be used together with the 16SZ :) Best regards Henrik Malmvig |
I've had that happen. What has worked for me is to unplug the battery and plug it back in. Also make sure the connections are correct and snug. I also use a fully charged pack. If the pack voltage is low it can also act up. I have programmed those exact servos with my 16SZ. All Futaba servos will work with all current Futaba radios.
